May 5, 2024 at 3:59 pm
哲 隋
SubscriberIf you use the spg unit to initialize the confining pressure loading stress and set the spg unit bond base to break, will there be stress fluctuations in the remaining units after the bond base breaks?
May 6, 2024 at 1:11 pm
Ram Gopisetti
Ansys EmployeeHi,Â
Would you be able to illustrate your issue with an example?
Cheers, Ram
- The topic ‘SPG SECTION’ is closed to new replies.
