TAGGED: AEDT-ICEPAK, ansys-icepak, icepak-thermal, wall-shadow
December 16, 2025 at 12:51 pm
860854801
SubscriberIn my model, the heat source distribution is highly non‑uniform. The clp function in Icepak does not work well (the manual also mentions this limitation). To deal with the non‑uniform heat source, I have divided the original heat source region into many smaller parts, about 60 blocks. The simulation results look reasonable and match my expectations physically.
However, I’m facing a performance problem:
When assigning losses to each block, during the preprocessing step after meshing and before solving, I noticed that some time is spent generating the wall-shadow, about 15 min. Please see the attached picture. If I do not apply these losses to the rectangular blocks, this preprocessing step becomes much faster.
Could you explain why adding losses to these blocks makes the wall-shadow generation so time-consuming? And is there any way to speed up this process when losses are applied?
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- simplorer-maxwell
4618
1535
1386
1210
