[Spectrum analysis] How to correctly apply damping ?
    • jean.collomb
      I am currently doing a spectrum analysis and I am comparing two methods:
      1. First, I use an existing APDL script ;
      2. Then, I try to do the same with Workbench Mechanical.
      In the APDL script, I have 2 commands for damping :
      1. DMPRAT : where my damping coefficient is implemented ;
      2. SV : where my damping coefficient and my spectrum is implemented.
      However, when I use Workbench Mechanical, in the spectrum system, I implement the damping coefficient. But when I look at the file.dat, I only see the damping coefficient in the DMPRAT command. The SV command contain spectrum values, but not the damping coefficient.
      When I compare results between these two methods, I obtain different results (due to the damping I suppose).
      My questions is:
      1. When I want to implement damping in a spectrum analysis (in Ansys Classic ou Workbench Mechanical), which command should I use ? (DMPRAT, SV, both ?)
      Thanks for your answer,
      Jean
    • danielshaw
      How are you applying damping in Mechanical?
  • The topic ‘[Spectrum analysis] How to correctly apply damping ?’ is closed to new replies.
