May 22, 2024 at 4:28 pm
David Pomeroy
SubscriberIs it possible to specify the memory mode from the command line?
I am new to Mechanical APDL and am using it to run workstation and cluster performance benchmarks (MAPDL_2022R1_Benchmark) on Linux virtual machine clusters using the command line. When I run the benchmarks in distributed memory mode, I often get a warning that there is insufficient in-core memory allocated even though the hardware has enough memory to run fully in-core. I found some suggestions to use the command "DSPOPTION,,INCORE". Is it possible to set this option at the command line without editing the benchmark .dat file, or are there other options I can use to force it to use more physical memory?
The command I am using is like this:
ansys -b -i {path}/V22direct-1.dat -np 88 -dis -mpi INTELMPI -machines=$(cat machine_file)
May 23, 2024 at 1:57 pm
mrife
Ansys EmployeeHi David
Warning are often ok - MAPDL has dynamic memory allocation so the warning about in-core might have been just a warning before MAPDL allocated itself more memory. Or it may have actually run out-of-core. Check the output file.
See the MAPDL Help Operations Guide chapter 4.1 on the command line options. There are two for memory that work hand-in-hand. -m and -db
Don't try to allocation all the available memory to MAPDL if the model does not require it - the OS will use memory for things like caching files for I/O etc. Â
Mike
May 23, 2024 at 4:42 pm
David Pomeroy
SubscriberNo, it definitely didn't fix the issue itself because I'm getting huge amounts of I/O and elapsed time exceeds CPU time by a significant amount.
I've tried using the -m option but it is not working as expected. To test this out, I'm running on one node with 88 cores, 4GB physical memory per core for a total of 352GB. I tried
-m 256000which should allocate a total of 250GB of memory, much less than the physical amount in the node, but what actually happened isTotal memory allocated for solver = 490.634 GBand then the run failed because it exceeded physical memory. So when the manual says that -m is the total workspace allocation, it doesn't seem to be functioning that way. I tried adjusting the value downward:-m 128000still allocated the same 490.6GB-m 64000allocated 477GB-m 32000allocated 373GB-m 16000allocated 166GBÂSo it does seem to affect the allocation, but in a nonlinear way. I haven't determined what multiplier or algorithm it's using. I tried
-m 3072to see if it allocates memory per core, but then it only allocated 163GB and was no better than if I didn't set -m.Any other ideas?
May 23, 2024 at 4:49 pm
mrife
Ansys EmployeeÂ
David
Well remember the command line -m is the initial allocation; MAPDL still can do dynamic allocation from there. Are you a commercial customer (I'd like to see the output file)? Also the value can be set to a negative number to force using a specific amount (and so turning off dynamic allocation). The -db size, which can also grow dynamically, is taken out of the -m amount.
- The topic ‘Specifying memory mode from the command line?’ is closed to new replies.
5819
