January 22, 2024 at 1:01 pm
chuminhkhue
SubscriberI analyze a computational model that represents thrombus formation in a straight channel.
I want to conduct the reaction pathway using the UDF file.
To mathematically implement biochemical species and reactions using the computational fluid dynamics package FLUENT.
picture below of the biochemical network represented in model of blood coagulation.
Q1:The species of blood are X, TF, Xa‐Va, TH, V, INACT, and AT. How to define species in Fluent know that species include diffusion coefficient and initial concentration.
Q2: After defining "the species source term ????_???? ([????_???? ]" by UDF file, how to apply it to the convection diffusion reaction equation (????[????_???? ]/????????+(???? ⃗.????)[????_???? ]=????_???? ????^2 [????_???? ]+????_???? ([????_???? ]))? -
January 22, 2024 at 2:18 pm
Forum ModeratorInitial concentration would be patch and/or a boundary condition. The species mixture can handle diffusion, and the flow solver the convection. Reaction rates can be chemistry based (Arrhenius rates), or you can code up a sink/source approach using Expressions or UDFs.
Have you reviewed and completed the relevent sections of Learning and solver tutorials? Note, you may not find a specific set of material but will instead need to take portions of several pieces of content.
January 23, 2024 at 3:55 am
January 23, 2024 at 12:09 am
chuminhkhue
SubscriberThank expert. I am going to continue the analysis.
January 23, 2024 at 9:57 am
Forum ModeratorYes. Add the species and then alter the mixture. You also need to decide if blood is a single fluid with species or a multiphase slurry: that will alter how you set up the mixture(s).
January 25, 2024 at 11:15 am
chuminhkhue
SubscriberCan I make a UDF that shows a liquid turning into a solid when it reaches the threshold?
After that, Ansys Fluent describes the behavior in two ways (fluid <-> solid formed) step by step.
Could you tell me the tool suitable for it?
January 25, 2024 at 11:20 am
Forum ModeratorSolid as in particles or solid as in freezing? We can do both, but the approach and outcome may be very different.
January 25, 2024 at 12:36 pm
chuminhkhue
SubscriberStep 1: To conduct a simulation for a liquid to turn into a solid when it reaches the threshold.
Step 2: Ansys Fluent describes the behavior in two ways (fluid <-> solid formed) over time.
Could you explain more details about this? Because I’m newbie, it’s hard to understand everything you said
January 25, 2024 at 1:11 pm
Forum ModeratorOK, very simple particles will flow, ie are carried with the fluid. A "solid" in the CFD sense is a big lump of stuff that won't move without a lot of coding. In blood I'd expect a small clot to be a particle; anything bigger may not need modelling as it's likely to be immediately fatal!
January 29, 2024 at 6:49 am
January 29, 2024 at 10:01 am
Forum ModeratorI can advise on solver side but am limited on advising on how to do physics. If you manage to figure out the full thrombosis mechanism I suspect you'll get a PhD as a minimum.
In terms of simulation, going from fluids to dispersed solids would be handled by the Eulerian or Mixture reactions (phase change); population balance may then give you options to grow the agglomerations.
February 9, 2024 at 11:28 am
chuminhkhue
SubscriberMy problem is that I have different “reaction rates” for each type.(mi)
I want to define ” reaction rate.”
Could I just apply the “volume reaction rate” by the UDF file for all reactions? without editing reactions in the material. Will macros overwrite the default reaction rate?
I don’t want to define it by reaction finite rate.
Could you tell me how to do that and if it is suitable for ansys fluent?
February 9, 2024 at 11:36 am
Forum ModeratorPass, what does the UDF say/do for the reactions?
February 9, 2024 at 11:57 am
- The topic ‘Species Transport, define species,Fluent technique(V.2022).’ is closed to new replies.
5664
1890
1419
1304
