October 17, 2025 at 12:13 am
Masato Yamaguchi
Subscriber①ネームドライセンスのSpaceclaimを使うために2020R2を入れてコマンドでアクティベートしようとするがエラーとなります。回避方法を教えてください。
Microsoft Windows [Version 10.0.26100.6725]
(c) Microsoft Corporation. All rights reserved. C:\Users\10073>cd C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64 C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64>ansysls_client.exe -ActivateLicenseEntitlement Act-1a2db4d3-d2a7-4f1c-a8d7-62fb02a0c1c9
2025/10/17 09:11:38 INFO Starting local server.
2025/10/17 09:11:38 INFO C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64\ansysls_client.exe -nodaemon -log C:\Users\10073\AppData\Local\Temp\.ansys\ansysls_client.DCD0761.log
2025/10/17 09:11:38 INFO Started ANSYSLI server.
2025/10/17 09:11:43 NEW_CONNECTION Connected to local subscription handler: 59925@127.0.0.1
2025/10/17 09:11:43 CLIENT_CONNECT 1/1/1/1 :: 6004
2025/10/17 09:11:43 DENIED Act-1a2db4d3-d2a7-4f1c-a8d7-62fb02a0c1c9 1/1/1/1 :: 6004 Curl Error (35) SSL connect error - schannel: failed to receive handshake, SSL/TLS connection failed
ERROR: Unable to activate entitlement with activation id 'Act-1a2db4d3-d2a7-4f1c-a8d7-62fb02a0c1c9', error:
Curl Error (35) SSL connect error - schannel: failed to receive handshake, SSL/TLS connection failed C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64> ②さらにAlgoryxMomentumをアドオンさせたいのですが バージョンは 何でしたら乗せられますでしょうか?
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
4102
1487
1318
1156
