August 26, 2020 at 8:48 am
Michele93
SubscriberAugust 26, 2020 at 6:38 pmAniket
Forum ModeratorI would rather take it to Mechanical (or meshing) and use virtual topology to create a plane surface there, you can also try merge operation in SpaceClaim but the VT is bit more tolerating for real life STL facets geometry.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forum nAugust 27, 2020 at 8:13 amMichele93
SubscriberClear! Thank you!nAugust 27, 2020 at 11:54 ampeteroznewman
SubscriberOne simple way to create one face is to create a plane at that end, then move the plane just slightly into the aorta solid and use the Split Body button to slice off the end with all those faces. You will end up with a singe face at the cutting plane after you delete the very thin slice you just split off.nViewing 3 reply threads- The topic ‘Spaceclaim surface subdivision’ is closed to new replies.
4989
1670
1386
1243
