October 9, 2024 at 4:54 pm
lespinom1600
SubscriberHello, I am somewhat new to ansys:
I want to run a parametric analysis with this geometry, setting the angle of that middle part as the parameter
And when I try to change that angle (the parameter) it just stops sharing topology.
I changed the parameter in the group section.
Is there a way to keep that share? I am taking a course and they did this this way in 2020R2, and they don't have this problem. I don't know if it is a version problem.
October 10, 2024 at 9:03 am
Deepak
Ansys EmployeeHi,
Does the middle part have a shared topology with other parts?
To address the issue of topology sharing stopping when you change the angle parameter in SpaceClaim, it's important to ensure that the parameter changes do not disrupt the geometry in a way that would break the shared topology.
Thanks,
Deepak
October 29, 2024 at 6:15 pm
October 31, 2024 at 10:39 am
Deepak
Ansys EmployeePlease check while moving the middle-angled cylinder whether it hits the shared topology surfaces.
October 31, 2024 at 10:44 am
5059
1764
1387
1248
