3D Design
3D Design
Spaceclaim Scripting TypeError: expected Plane, got Plane
    • Niklas Sellmann
      i try to create an ACT wizard extension for spaceclaim. I already wrote a code that creates a geometry in spaceclaim and it works fine when i start it directly in the scripting extension of spaceclaim.
      For the ACT version i have an issue with the creation of a planar body. The following part of the code creates an error:
      import clr
      import units
      import time
      clr.AddReference("SpaceClaim.Api.V23")
      from SpaceClaim.Api.V23.Geometry import *
      from SpaceClaim.Api.V23.Modeler import *
      #polGen is a List[ITrimmedCurve] of curvesegments
      refPlane=Plane.PlaneZX
      face1 = PlanarBody.Create(refPlane, polGen)
      body1= face1.CreatedBody
      The row, where PlanarBody.Create is executed, creates the following error in the ACT Log console:
      I can't find a solution to this problem, does anybody know how to solve this?
    • ErKo
      Hi
      This should help (change v19 to v23 in the below script).
      https://discuss.ansys.com/discussion/653/how-to-import-spaceclaim-api-packages-in-act
      Should you have any more questions post it in that forum (dedicated to scripting)
  • The topic ‘Spaceclaim Scripting TypeError: expected Plane, got Plane’ is closed to new replies.
