3D Design
3D Design
SpaceClaim plug in on WorkBench
    • ofrik
      hi, until now i used SpaceClaim and it appeared automatically on the workbench.
      it suddenly changed to DesignModeler and i cant find out how to fix it.
      on the workbench options > geometry impore , spaceclaim dierct modeler is checked.
      thank you
      Odd, please can you repost the image into the text so I can see it? Staff are not permitted to download/open attachments.
    • ofrik
       thank you !
      Right click on the Geometry box, can you edit in SpaceClaim?
    • ofrik
      these are the option i get. on the right side of the screen i have a 'CAD plug in' box but i cant edit it.
      If you right click on "Geometry"  are there options for "Edit in DM" and "Edit in SC"?
    • ofrik
      unfortunately no...
    • tsiriaks
      For some reason, the tool doesn't see SpaceClaim license anymore.
      Open up CMD Prompt, then issue the following command (change 1## to the correct version)
      "%awp_root1##%..Shared FilesLicensingwinx64ansysli_util" -checkout SPACECLAIM
      what is the output of this ? does it fail ?
Viewing 7 reply threads
  • The topic ‘SpaceClaim plug in on WorkBench’ is closed to new replies.
