June 7, 2021 at 12:25 pm
June 8, 2021 at 6:11 am
Naresh Patre
Ansys EmployeeHello Lukas
I am not sure if it's possible to change the thread information. Let me check with the team and get back to you.
June 8, 2021 at 8:20 pm
Josh Suneby
Ansys EmployeeHi  Lukas If you right-click the dimension, you can select "Detach from Dimension." This will allow you to edit the dimension annotation. However, this breaks the connection with the dimension such that, if you change the standard hole size/type, the changes will not occur in the annotation (and you will have to re-add the dimension annotation). I will file an enhancement request for the Czech translation of Tap Drill to be more succinct.Â
June 9, 2021 at 6:54 am
Lukas Janicek
SubscriberHi Josh SunebyÂ
I know I can use the Detach from dimension, but there is the problem you wrote about.
Thank you, Lukas
- The topic ‘SpaceClaim – info of thread’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
4512
1494
1386
1209
