July 24, 2020 at 8:49 pm
zjuv9021
SubscriberHi all,
I am attempting to export my geometry from Spaceclaim into an Abaqus friendly format (ACIS, .sat, .stp), but no matter what I do I get the following error in Abaqus after attempting an import:
Has anyone utilize Abaqus before and figured out how to best approach? I've tried different protocol #, etc.. Perhaps I'm missing something simple here?
July 25, 2020 at 2:09 am
peteroznewman
SubscriberWhat version of ABAQUS/Pre are you using? Is it an older version?
One failure mode for moving geometry between systems is when the version of the neutral file on the exporting system is newer than the version of the neutral file that the importing system can read.
The newest version of SpaceClaim can export V29 of the ACIS kernel, but an older version of ABAQUS/Pre might be using V27 and can't read V29.
Find out what version of ACIS is being exported by ABAQUS and export that version from SpaceClaim.
- The topic ‘Spaceclaim importing geometry into Abaqus – Error’ is closed to new replies.
5149
1831
1387
1248
