3D Design
3D Design
SpaceClaim gives me a “not responding error” after trying to share topology.
    • Damian Rodolfo
      For some reason the model im working with is having issues after i attempt to modify the model and then reshare topology. I will make the modifatiions without and issue, but when i attempt to share topology it loads gives me a "there is no coincident topology" message and then says "(Not Responding)" at the top. I know there is coincident topology that needs to be shared so im confused on why it gives me that message. Shortly after though it becomes un responsive and i have to end task the program. Has anyone else encountered this issue and if so how do i fix it?
    • Keyur Kanade
      Please check geometry in SpaceClaim.
      Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
      The geometry should be error free to proceed.
      If geometry has any errors, please modify/recreate geometry at those places.
      If you have multiple components please make only few components visible and then use Share. It works on only visible bodies. This way you can find which body is giving issue.
      Keyur
      Fluids Engineering Courses | Ansys Innovation Courses
  • The topic ‘SpaceClaim gives me a “not responding error” after trying to share topology.’ is closed to new replies.
