3D Design
3D Design
SpaceClaim gives me a “not responding error” after trying to share topology.
    • Damian Rodolfo
      For some reason the model im working with is having issues after i attempt to modify the model and then reshare topology. I will make the modifatiions without and issue, but when i attempt to share topology it loads gives me a "there is no coincident topology" message and then says "(Not Responding)" at the top. I know there is coincident topology that needs to be shared so im confused on why it gives me that message. Shortly after though it becomes un responsive and i have to end task the program. Has anyone else encountered this issue and if so how do i fix it?
    • Keyur Kanade
    • Devendra Badgujar
      Hello Damian,
      Can you please try increasing the Coincidence tolerance to see if that helps? Make sure bodies to be shared are visible as hidden bodies are ignored.
      Also, can you try unsharing and sharing it again. Let me know if that works.
      Devendra
  • The topic ‘SpaceClaim gives me a “not responding error” after trying to share topology.’ is closed to new replies.
