October 13, 2021 at 1:55 pmardaozuzunSubscriber
I have two question.
1) Can I automatically select the edges of nameselection or edges of previously selected faces?
2) I could not find keyboard shortcuts for edge selection filter in customize shortcuts section. Is there a shortcuts for selection filters?
regards
October 26, 2021 at 12:50 pmbhagwantPAnsys Employeehope following two link will work as guiding point for your concern:
ANSYS named selections (spaceclaim.com)
How to change selection filter to select only edges in SpaceClaim? ÔÇö Ansys Learning Forum
Thanks
Viewing 1 reply thread- The topic ‘Spaceclaim Edge Selection Question’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- ICEM CFD – Hexa mesh of a tapered wing with sharp trailing edge
- No mesh information was found in the input mesh file error
- CONVERTING STL FILE IN TO SOLID
- Varying ply angle in ACP
- Element type definition – Ansys Workbench
- ANSYS ACP Modelling Issue
- the matrix T in the cyclic symmetric formula!!
- Assiging one parameter as thinkness of few shell objects
- The meshing algorithm cannot find matching topology
- Connecting External Mesh and Beam Model in Ansys Workbench
Top Contributors-
1406
599
591
555
366
