3D Design
3D Design
SpaceClaim command problem
    • Roberto Granito
      Hello
      The command shown in the photo no longer seems to work, it is not possible to memorize the orientation, if I click on memorize nothing happens
      Regards
    • Devendra Badgujar
      Hello Roberto,
      Does this happen with any specific file? Try resetting your options. Go to File > SpaceClaim Options > Advanced > Reset All User Settings.
      Try Deleting the contents of %appdata%\Local\SpaceClaim.
      If you continue to run into problems, please send me a recent SpaceClaim log file (from the error session).
      The SpaceClaim log files can be found in C:\Users\\AppData\Roaming\SpaceClaim\Log Files.
      (Sometimes the AppData folder is hidden. To find it, type %appdata% into the file path and press enter)
      Devendra
    • Roberto Granito
    • Devendra Badgujar
      Resolved after resetting the user settings.
  • The topic ‘SpaceClaim command problem’ is closed to new replies.
