July 20, 2024 at 10:25 am
glab17
SubscriberHi there is a way to exclude some operations from block recording in Spaceclaim without delete all the operations made before? I noticed that if I close blocks and I do some operations then the open again blocks it is empty.
July 22, 2024 at 5:43 am
Keyur Kanade
Ansys EmployeeTypically, when you close blocks and then perform some operations, if you open the blocks again and find it empty, it suggests that the operations performed while the blocks were closed were not recorded. If you want to perform operations without them being recorded in a block, you would need to ensure that block recording is turned off during those operations. To manage block recording, you can turn it on or off as needed. When it's off, the operations you perform won't be captured in the blocks. Remember to turn it back on when you want to resume recording operations in blocks.
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
- The topic ‘Spaceclaim block recording’ is closed to new replies.
5674
1890
1419
