TAGGED: api, Moderator SpaceClaim, script, spaceclaim
January 17, 2024 at 6:53 am
January 17, 2024 at 10:09 am
Atharv Joshi
Forum ModeratorHi Alex,
SpaceClaim script editor has 2 modes(Run, Debug) for executing the script.
While using InputHelper command the script should be executed in Debug mode.
This allows the scipt to pause and take user input.Thanks and Regards
Atharv -
January 17, 2024 at 10:46 am
user deleted
SubscriberHi Atharv, If you mean the editor for Python, then I know this information.
But I need to call "InputHelper.PauseAndGetInput" from c#. Inside the "InputHelper.PauseAndGetInput" checks that the "ScriptHelper.OnScriptingThread" field is true, otherwise an exception is thrown. How to call "InputHelper.PauseAndGetInput" so that "ScriptHelper.OnScriptingThread" is true?
January 17, 2024 at 2:21 pm
Atharv Joshi
Forum ModeratorLet me check for C# calls that run the script in debug mode.
January 29, 2024 at 6:16 am
Atharv Joshi
You can try executing the script as RunScriptAsync, instead of RunScript.
This may help with pasuing the script. Let me know if it works.
Regards
Atharv
- The topic ‘SpaceClaim Api Scripts C#’ is closed to new replies.
5799
