July 11, 2024 at 12:08 pm
Bennett Teitle
SubscriberHello, I wanted to make a post about an issue I have recently encountered with the API user interface. I an making a script that will autodimension a cross section of a solid object first by cutting it via splitbody, and then running a for loop to add all target faces to be measured to a list. Here is the problem:
When I split the solid it creates two bodies and deletes one. I want to be able to access this remaining body's attributes so that I can say "For every face in this body, do this operation." I have experiemented with the IDesignFace and IDesignBody classes, but just can get anything to stick without the script saying "expected array [Type], got int", or "unexpected token'('" when I eventually run the append operation. Can anyone help?
July 12, 2024 at 9:53 am
subashni.satish
Forum ModeratorHello Bennett,
Let me try this operation from my end and get back to you.
- The topic ‘SpaceClaim API Scripting Classes Issue’ is closed to new replies.
5824
