December 30, 2025 at 5:27 pm
1260960796
SubscriberIn SpaceClaim, If there is a straight line segment, how can I create a sketch plane(or say workplane) which is through an endpoint and perpendicular to the line segment?
What’s more, If the endpoint is shared by several line segment, the sketch plane result is sole when I place my cursor on the endpoint. That means the sketch plane is only perpendicular to one certain line segment that I can’t specify which line segment. -
December 30, 2025 at 5:56 pm
1260960796
SubscriberBecause I need create a section pattern in a plane which is perpendicular to the line and pull the pattern along the line. -
January 5, 2026 at 11:05 am
Charudatta Bandgar
SubscriberHello,
I would suggest you create a coordinate system first, this will create an x,y,z coordinate, of which one of the axis will be parallel to the line. If you create a plane using this axis, you would get a plane that is parpendicular to the line. Then you can move this plane to the endpoint, using the move tool.Â
Let me know if that helps.
Thanks and regards,
Charudatta B
5669
1890
1419
1304
