December 9, 2024 at 8:19 am
maruidiyi2
Subscriber当我在spaceclaim中建立一个script,它是可以正常运行的。但是当我尝试建立一个wizard来封装script时,程序无法运行。在log文件中显示
Error when invoking function 'QFN'.
Traceback (most recent call last):
File "D:\0插件库\spaceclaim\ACT\SoledrjointGen\SoledrjointGen\SolderjointGen_main.py", line 717, in QFN
StandardError: Exception has been thrown by the target of an invocation.
ImportError: Cannot import name GetAllBodies
我已经在py文件的开头进行以下声明
import os, sys
clr.AddReference("Ans.Utilities")
from Ansys.Utilities import ApplicationConfiguration
version = ApplicationConfiguration.DefaultConfiguration.VersionInfo.VersionString
sys.path.append(os.environ["AWP_ROOT"+version]+"/scdm/Scripting")
clr.AddReference("SpaceClaim.Api.V20".format(version))
clr.AddReference("SpaceClaim.Api.V20.Scripting".format(version))
exec('from LoadSCDMAPITypesV20 import *'.format(version))
exec('from UtilitiesOnLoadV20 import *'.format(version))
有人知道为什么吗? -
January 27, 2025 at 11:02 am
Ashish Khemka
Forum ModeratorHi,
I am not an expert but saw similar error on another forum post. Try running Ansys as admin and see if that helps: ACT Wizard: Machine Toolkit Error
Ashish Khemka
January 27, 2025 at 3:57 pm
George Karnos
Ansys Employeealso, try using a directory that is only ASCII characters, English language.
- 您必须登录才能回复此主题。
4597
1495
1386
1209
