May 8, 2024 at 8:48 am
nisarg.dave1
SubscriberHello,
Good morning! I hope you are keeping well.
While importing 3D model of a motor from spaceclaim to Maxwell 3D, I am unable to give any orientation (CS) to the magnets. The "Orientation" tab in the "Properties" is not allowing me to select the CS that I have created. I have tried adding new material, importing a material from PersonalLib. Although this problem is not there while building the model in Maxwell. I am using Maxwell 2023 R2 for your reference. This issue is not there in 2023 R1. Kindly give me solution of the same thanks.Â
Thank you for your time and support.
Best regards,
Nisarg
May 9, 2024 at 4:13 pm
GLUO
Ansys EmployeeHi,Â
Could you try select the magnet, modeler>>export as parasolid format, and re-import the magnet? this re-format the magnet and clean up its history, making it an individual part. Then the orientation can be changed.
GL
May 13, 2024 at 12:53 pm
nisarg.dave1
SubscriberThank you for your reply, the issue is solved now. Cheers
- The topic ‘spaceclaim 3D import Maxwell’ is closed to new replies.
