3D Design
3D Design
Spaceclaim 2024 error FNE activation failed
    • matthieu.rouillier
      I work in the IT department and a user has the error “FNE activation failed” on her version of spaceclaim 2024.
      I've referred to several sections on your site, but the solutions you suggest above haven't solved the problem...
      Here are the sources of the solutions I tried:
      FNE activation Error
      FNE Activation Failed. Peer certificate cannot be authenticated with given CA certificates | Ansys Knowledge
      Discovery SpaceClaim License Activation Error
      Can you help me please ?
    • George Karnos
      Hello Mathieu,
      Are you using shared web licensing or do you have a physical license installed on a machine
      at your location?
        Hello George,
        This is a Legacy Named User Subsciption
      Hello George,
