August 27, 2020 at 12:48 pm
Yohann Biran
SubscriberA customer have downloaded the latest version of Ansys Spaceclaim 2020 R2, but does not work. It asks for username and password and then nothing happens.
We try to sart in administrator mode, we also try to activate the license with cmd but it's not solve the problem.
He has no error message.
Could you please suggest a solution?
August 27, 2020 at 2:31 pm
Roberto
SubscriberNOVACAD Hello
I also had this problem in some places on Windows 7.
Is the workstation where this error occurs Windows 7 installed?Â
Best Regards
August 28, 2020 at 7:18 am
Charudatta Bandgar
Forum ModeratorHello NOVACAD and Robert ,
This problem has been noticed by other customers before as well, and apologies for the inconvenience. We have highlighted it to the concerned people.
Although the workaround suggested by them was to activate the license with command prompt, and that has worked for other customers. Can you please share a snapshot of the command prompt along with the temp folder as a zip file?
Although I am not sure whether this is the cause of it, if it is a frequently noticed observation, I will highlight this too to the concerned people.
Regards.
August 28, 2020 at 7:23 am
Roberto
SubscriberCharudatta Bandgar Hello
The problem happened to two different customers who had Windows 7, then I solved it by installing the previous version 2020R1.
Trying to activate it with the command prompt it told me that the license was successfully activated but the software never started.
From the management of the activities did not load anythingBest Regards
August 28, 2020 at 8:24 am
Charudatta Bandgar
Forum ModeratorOkay, RobertÂ
I will highlight both of these points to concerned people.
Regards.
August 28, 2020 at 9:53 am
Yohann Biran
SubscriberHi charudatta,
Where IÂ can find the temp folder ?
August 28, 2020 at 3:58 pm
Roberto
SubscriberHelloÂ
Usually the folder is in this file path  C:UsersNameAppDataLocalTemp
and is called .ansys
August 31, 2020 at 1:38 pm
Yohann Biran
SubscriberHi,Â
You can find attached the temp file and the snapshot of the command prompt.
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions-
September 14, 2020 at 7:47 am
Charudatta Bandgar
Forum ModeratorHello NOVACADÂ ,
Sorry for the delayed response. Can you please send the customer's registered email ID to ansys-discovery-support@ansys.com?
September 11, 2020 at 5:04 pm
info
SubscriberHi Charudatta,
ÂThe problem still exists. The license is activated but SpaceClaim does not start with the user account.
It starts with an administrator account.
User has permissions to write to :Â
%LOCALAPPDATA%
%Temp%Here is the log file and the .ansys file attached.
Thanks for your help.
September 14, 2020 at 7:48 am
Charudatta Bandgar
Forum ModeratorHello GUICAD ,
It starts with an administrator account. Does the customer have administrator rights?
Regards.
September 14, 2020 at 9:10 am
info
Subscriber-
September 16, 2020 at 11:35 am
Charudatta Bandgar
Forum ModeratorHello GUICADÂ ,
I am not able to find the root cause of this issue. There is one more thing we can try doing.
Can you ask the administrator for this account to run the Discovery mode licensing manager as administrator.Â
And then change the scope to all users.
Once that is done, ask the customer (who does not have admin rights), to try and use the software with their login.
Regards.
September 22, 2020 at 10:08 am
Charudatta Bandgar
Did this work for you?
Regards
September 22, 2020 at 10:13 am
info
SubscriberHello Charudatta,
Unfortunately no...
September 25, 2020 at 12:31 pm
tecnico
SubscriberSAME PROBLEM WITH 2019 R3
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
October 1, 2020 at 10:43 am
Roberto
Hello
I point out that to several customers the software does not start by clicking on the icon after being installed and you have to activate it first with the command prompt and then start it from the icon.
Sometimes it doesn't even start that way.
Do you have any news regarding the problem?Best Regards
October 16, 2020 at 6:49 am
Roberto
SubscriberHello Charudatta Bandgar
I am installing other SpaceClaim to customers and always have to activate them with the command prompt at first start.
I hope it doesn't stay that way in the next version.Â
Best Regards
- The topic ‘Spaceclaim 2020 R2 not launch’ is closed to new replies.
- Unable to attach geometry 2024 R2
- Data Center Simulation
- DXF file loaded incorrectly
- Inventor 2025 files
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- [SpaceClaim] STEP file size using Converter.exe
- Spaceclaim 2024 error FNE activation failed
- How to do the snap fit insertion FEA?
- Ansys Discovery Crashing vGPU (Reproducible)
2202
918
599
591
494
