July 21, 2021 at 3:27 pm
veera
SubscriberDear all
I am working one more complicated geometry , in that there is gap exist between one bounded components to other components. actually I need interface between the components for that I need o mm tolerance between them .
Pls help anyone to rectify this problem in space claim easily . I know with pull option we can do it , but geometry is not flat and also more complicated one (bounded surface)
July 21, 2021 at 3:30 pmJuly 27, 2021 at 12:25 pmAniket Chavan
Forum ModeratorNot sure which bodies you mean in the inline image, but you can try the following options:
create copies of the two surfaces and create a blend between the two surfaces (https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/spaceclaim/Discovery/user_manual/blending.html )
use the Pull Upto option (https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/spaceclaim/Discovery/user_manual/pulling.html)
or simply pull the geometry so that it overlaps with other body and then use combine tool to subtract the excess material (https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/spaceclaim/Discovery/user_manual/intersecting_combining_and_splitting.html)
-Aniket
Viewing 2 reply threads- The topic ‘space claim gap between two complicated bounded components’ is closed to new replies.
5649
1885
1404
1303
