April 29, 2021 at 3:00 pm
daniellyb
SubscriberHello,
I'm doing a 3D magnetostatic simulation using the full geometry of a motor, therefore, I don't have any master-slave boundaries. It was previously working, and then it stopped in the 6th adaptive pass. The following error message was displayed:
 Maxwell3DDesign1 (Magnetostatic)
  [error] Source setup error, possible reasons are 1) The solved region is not singly connected. If any circle in the solved region can not be freely shrunk to a point, then solved region is not regarded as singly connected. 2) The master and slave boundaries are separated. For this case, “Zero Tangential H Field?boundary condition need to be assigned on one boundary connecting master and slave boundaries. (11:54:55 abr 29, 2021)
  [error] Simulation completed with execution error on server: Local Machine. (11:54:56 abr 29, 2021)
I've tried to simulate it again, and it is aborting even before complete the 1st adaptive pass. What does this error means and how can I check where the problem is?
Thank you
May 3, 2021 at 9:02 amNKC
You can right-click on the results and do cleanup solutions close the design and delete any locked files from the project directory.
also, delete the temporary files and cache from the computer.
Now reopen the design and analyze.
If this did not work please share some screenshots of your model and setup.
Regards Navya
July 14, 2023 at 5:53 amJitender Sharma
SubscriberHi Team ANSYS Support,Â
I have exactly the same error. i have tried the above steps but still the same issue. kindly suggest the steps to overcome this failure.
*simulation validation check completed without any warnings and errors.
Thank You.
Viewing 2 reply threads- The topic ‘Source setup error – The simulation was working previously’ is closed to new replies.
Innovation SpaceTrending discussions- Three-Phase Voltage Imbalances in dual stator electric generator
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
Top Contributors-
4597
1495
1386
1209
