July 9, 2024 at 8:32 am
洋 于
SubscriberI am doing research on foaming simulation. The udfs of the water component conversion rate Xw and hydroxyl component conversion rate Xoh source terms are as follows. Why does the rate of change become very small as the calculation proceeds and can almost be ignored? Yes, please give me some advice
DEFINE_SOURCE(uds_source_W, cell, sec_th, dS, eqn){real P = C_P(cell, sec_th)+101325;real T = C_T(cell, sec_th);real Xw = C_UDSI(cell, sec_th, 0);real Xoh = C_UDSI(cell, sec_th, 1);real P_bar = P / 100000.0;Âreal source_W;Thread*mix_th;Thread*pri_th;mix_th = THREAD_SUPER_THREAD(sec_th);pri_th = THREAD_SUB_THREAD(mix_th, 0);sec_th = THREAD_SUB_THREAD(mix_th,1);source_W =K_X*C_R(cell, sec_th) * C_VOF(cell, sec_th) * Aw * exp(-Ew / (R * T )) * (1 - Xw);dS[eqn] =K_X*C_R(cell, sec_th) * C_VOF(cell, sec_th) * Aw * exp(-Ew / (R * T ));return source_W;}ÂDEFINE_SOURCE(uds_source_OH, cell, sec_th, dS, eqn){real P = C_P(cell,sec_th)+101325;real T = C_T(cell, sec_th);real Xw = C_UDSI(cell, sec_th, 0);real Xoh = C_UDSI(cell, sec_th, 1);real P_bar = P / 100000.0;real source_OH;Thread*mix_th;Thread* pri_th;  mix_th = THREAD_SUPER_THREAD(sec_th);pri_th = THREAD_SUB_THREAD(mix_th, 0);sec_th = THREAD_SUB_THREAD(mix_th,1);source_OH = K_X * C_R(cell, sec_th) * C_VOF(cell, sec_th) * Aoh * exp(-Eoh / (R * T )) * coh0 * (1 - Xoh) * (cnco0 / coh0 - 2 * (cw0 / coh0) * Xw - Xoh);dS[eqn] = K_X * C_R(cell, sec_th) * C_VOF(cell, sec_th) * Aoh * exp(-Eoh / (R * T )) * coh0 * ((-2 * cw0 / coh0) * (1 - Xw) * cnco0 / coh0 - 2 * Xw * cw0 / coh0 - Xoh);return source_OH;}ÂDEFINE_SOURCE(uds_source_Qe, cell, thread, dS, eqn){real P = C_P(cell, thread)+101325 ;real T = C_T(cell, thread);real Xw = C_UDSI(cell, thread, 0);real Xoh = C_UDSI(cell, thread, 1);real P_bar = P / 100000.0;real Hoh = 7.705e4;real Hw = 8.6e4;real dXoh_dt = Aoh * exp(-Eoh / (R * T)) * coh0 * (1 - Xoh) * (cnco0 / coh0 - 2 * (cw0 / coh0) * Xw - Xoh) ;real dXw_dt = Aw * exp(-Ew / (R * T )) * (1 - Xw) ;real source_Qe;Thread* pri_th;Thread* sec_th;pri_th = THREAD_SUB_THREAD(thread, 0);sec_th = THREAD_SUB_THREAD(thread,1);source_Qe = K_X * C_R(cell, sec_th) * C_VOF(cell, sec_th) * (Hoh * coh0 * dXoh_dt + Hw * cw0 * dXw_dt) / Rpu;dS[eqn] = 0;return source_Qe;}Â
July 9, 2024 at 10:46 am
Forum ModeratorCheck all the variables are defined. Then look at the values you're using and see what's going on in the model. Note, from the source names are these the values of the source, or a UDS?
- The topic ‘Source item udf’ is closed to new replies.
1565
1386
1242
