April 17, 2020 at 7:31 pm
Marsha
SubscriberHi,
I'm new in Ansys. I'm working with Q3D Extractor. I have a PCB ODB+ file imported to ANSYS Q3D Extractor.
I tried to set the source and sink on the face of the pad that is supposed to produce current, but, every time I try to run the simulation I receive the following error:
  [error] Terminal 'Source1': Terminal can not be placed in whole or in part on a surface that is the intersection of two conductors (2:05:26 PM Apr 17, 2020)
  [error] Terminal 'Sink1': Terminal can not be placed in whole or in part on a surface that is the intersection of two conductors (2:05:26 PM Apr 17, 2020)
I searched in the net but couldn't find an answer!
January 23, 2021 at 4:11 am
Mayank
SubscriberTry to assign a source and sink to faces which are not intersecting with other objects. In simple language try to assign source and sink to the end faces of nets .nn
- The topic ‘source and sink defining Error in Q3D’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1318
1157
