November 15, 2022 at 11:28 pm
Joseph Loveless
SubscriberHello All,
Have any of you had an issue importing geometry from NX into a static structural analysis? What I'm seeing is some solids dropping off in the assembly when imported. No errors are shown, just missing parts. It varies on assembly as well, which solids get dropped.
Thoughts?
Thanks,
Joe
November 16, 2022 at 8:55 am
Aniket
Forum ModeratorHi Joe,
I am assuming you are not using the student version of the software as it includes following gepmetry type imports:- Neutral format import IGES, STEP
- Parasolid (native within Ansys DesignModeler)
Assuming you have a commercial license, If you are using reader mode, please check:
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v222/en/ref_cad/cadNXreader.htmlÂ
in case you are using plugin mode, please check:
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v222/en/ref_cad/cadNXassocGeo.html
Also, check mixed import settings.
Aniket
- The topic ‘Some Solids Disappearing on Import from NX’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
4067
1487
