July 25, 2024 at 4:52 am
Yifan Chen
SubscriberHello everyone, I am using Fluent to simulate the cooling of a battery pack, using the most basic Realizable k-e model. I want to try to change the flow rate or temperature of the coolant. I would like to ask you, if I change these two conditions, what changes do I need to make to the boundary conditions? Do I need to modify the heat transfer coefficient? Or is the heat transfer coefficient automatically calculated by Fluent based on the boundary conditions, and I don't need to modify it?
July 25, 2024 at 9:24 am
Forum ModeratorWhich heat transfer coefficient? Fluent will calculate any heat transfer between fluid & solid zones and you can report the HTC on those walls (read the definitions in the manual to understand what you're reporting).
July 27, 2024 at 2:11 am
Yifan Chen
SubscriberThank you very much for your reply. What I want to consider is the Surface Heat Transfer Coefficient. I checked the guidebook and concluded that Fluent will automatically calculate the Heat Transfer Coefficient according to the boundary conditions (including the inlet temperature and speed of the coolant) during the simulation and apply it in the simulation. I don't know if my conclusion is correct. I hope you can enlighten me.
July 29, 2024 at 10:58 am
Forum ModeratorFluent will calculate the heat transfer, and then can report the heat transfer coefficient for the wet walls. Note the distinction. HTC is a made up number to assist engineers in comparing designs where surface area/flow/stuff may be very different.
August 1, 2024 at 7:36 pm
August 2, 2024 at 8:34 am
Forum ModeratorDoes the tube axis align with the y-axis?
August 2, 2024 at 6:02 pm
August 5, 2024 at 12:50 pm
Forum ModeratorIf you're plotting on the inlet, which has only one value of x, why wouldn't you get the plot you're seeing?
- The topic ‘Some questions about the heat transfer coefficient’ is closed to new replies.
5669
1890
1419
1304
