Photonics
Photonics
some questions.
    • ashish.singh
      1st question . can you describe how you guys have calculated purcell.
      2nd. do setting sim temp automatically ecalculates refractive index changes due to change in temp ?
      3. if i add  user property in one of the sturcture group how can i call the same varibale in one of my analysis groups.
    • Guilin Sun
      Purcell factor examples:
      https://optics.ansys.com/hc/en-us/articles/4412965836947-Purcell-factor-dipolepower-vs-transmission-box
      https://optics.ansys.com/hc/en-us/articles/360042225934-OLED-2D
      1D high-Q cavity
      if it is layered structure, you can use analytical solution: stackpurcell – Script command
      for thermal-optic simulation, please refer to
      Thermally tuned waveguide (FDE)
      Lithium Niobate Nonlinear Thermal Waveguide
      Thermally tuned waveguide sensor
      for the last question, you can either insert the structure inside the analysis group:
      Metamaterial parameter extraction – Smith
      or you will need to pass structure variable to “model”, and the “model” passes the same variable to the analysis group. It is better to have the structure inside the analysis group.
      For further questions, please write new post, as the forum policy is one question one post, so to target one question with one solution.
