July 18, 2024 at 2:02 pm
jie li
SubscriberWhen simulating the case ("Diffuse Scattering Film for Automotive Display") in the case base, I found that some of the script commands as as follows. What is the meaning of " norm_calc = exp( -(Theta/beam_width)^2 ); "
norm_calc = exp( -(Theta/beam_width)^2 ); # Where Theta_out is the matrix of reflection angles,and Theta = meshgridx(theta_out,phi_out); beam_width=2
beam_norm = integrate(norm_calc*sin(Theta*pi/180),1:2,theta_out*pi/180,phi_out*pi/180);
beam_norm = 1/beam_norm;
BTDF(fc,1,1,:,:) = pinch(BTDF(fc,1,1,:,:)) + beam_norm*Ttotal(fc)*order_T(n,m,fc)*exp( -(ThetaDiff/beam_width)^2 );
The complete code is as follows:
theta_out = linspace(0, 90, n_theta_out);
phi_out = linspace(0, 360, n_phi_out);
monitor_nameT = "T";
monitor_nameR = "R";
f = getdata(monitor_nameT,"f");
lambda = c/f;
# Get refractive indices
dim = getdata("R", "dimension");
if ( (dim==2) & (%polarization angle% == 90) ) {
index_R = real(getdata("index_R", "index_z"));
index_T = real(getdata("index_T", "index_z"));
} else {
index_R = real(getdata("index_R", "index_x"));
index_T = real(getdata("index_T", "index_x"));
# calculate Theta and Phi grids
Phi = meshgridy(theta_out,phi_out);
Ux = sin(Theta*pi/180)*cos(Phi*pi/180);
Uy = sin(Theta*pi/180)*sin(Phi*pi/180);
Uz = cos(Theta*pi/180);
Ttotal = abs(transmission(monitor_nameT));
if (dist>0) {
Rtotal = 1 - abs(transmission(monitor_nameR));
} else {
Rtotal = abs(transmission(monitor_nameR));
# T
BTDF = matrix(length(lambda),1,1,length(theta_out),length(phi_out));
Ttest = matrix(length(lambda));
order_T = grating(monitor_nameT, 1:length(f), index_T, direction);
order_T_ux = gratingu1(monitor_nameT, 1:length(f), index_T, direction);
order_T_uy = gratingu2(monitor_nameT, 1:length(f), index_T, direction);
for(fc = 1:length(f)) {
for(n=1:length(order_T_ux(:,fc))) {
for(m=1:length(order_T_uy(:,fc))) {
order_uz = sqrt( 1 - order_T_ux(n,fc)^2 - order_T_uy(m,fc)^2 );
if( (order_T(n,m,fc)!= 0) & (imag(order_uz) == 0.) ) {
Tux = cos(-phi_in*pi/180)*order_T_ux(n, fc) - sin(-phi_in*pi/180)*order_T_uy(m, fc);
Tuy = sin(-phi_in*pi/180)*order_T_ux(n, fc) + cos(-phi_in*pi/180)*order_T_uy(m, fc);
ThetaDiff = real(acos( Ux*Tux + Uy*Tuy + Uz*order_uz ) * 180/pi);
Ttest = real(integrate(pinch(BTDF)*sin(Theta*pi/180),1:2, theta_out*pi/180, phi_out*pi/180));
July 22, 2024 at 4:55 pm
Greg Baethge
Ansys EmployeeHi Jie Li, thanks for posting your question. In this workflow, the BSDF is calculated using grating projection. The number of grating orders will depend on the width of the simulation region. In our initial example, this width was used to control the "resolution" of the BSDF.
For the export to Speos, the BSDF is calculated on a fixed grid. To do so, we map each grating order with a Gaussian beam of fixed width (beam_width). "beam_norm" is used as a normalisation factor to make sure power is conserved in the process.
- The topic ‘Some problems in the case base(“Diffuse Scattering Film for Automotive Display”)’ is closed to new replies.
