June 4, 2023 at 8:09 am
Zhenhao Qian
SubscriberWhen I fitting the shear relaxation curve, I found I must define the elastic modulus, but I don't know which modulus should I define, Instantaneous modulus or equilibrium modulus?
June 5, 2023 at 3:48 pm
John Doyle
Ansys EmployeeAssuming this is a small strain application, the base material can be defined with the instantaneous linear elastic modulus and Poisson's ratio.
If this is a large strain application for a polymer type material, consider defining base material as a hyperelastic strain energy density function.
July 2, 2023 at 8:40 am
Zhenhao Qian
SubscriberÂ
Thank you for your reply! And I’ m sorry about my late reply.
I also have some questions
- Would I interpret small strain as the part before plastic stage?Â
- Before I do stress relaxation test about my material, I do uniaxial compression test to confirm its linear elastic stage. Because as far as I know, the stress relaxation test must ensure that it is within the linear elastic stage of material. Due to limitations, I can only apply load at a low speed (about 10mm/min to 60mm/min), I ‘m not sure how to confirm the linear elastic stage, because before 0.2 strain, the uniaxial curves don’ t seem to be completely ‘ linear‘ . I’ m not sure whether my understanding is correct.
The figure shows the uniaxial compression curves. Red line = 10mm/min, Blue line = 60mm/min.
- The topic ‘some problem of defining prony shear relaxation parameter’ is closed to new replies.
1890
1419
1304
