March 19, 2024 at 4:55 amSaurabh BorateSubscriber
I was asked a question in my interview that whether we can solve convective term in MRF analytically?
What should be the correct answer to this.
I explained him in terms of the equation that is present in fluent's theory guide. Like Yes, we can solve the equation by finding out the relative velocity vr = v(abs) - ur (velocity of the moving
frame relative to the inertial reference frame). -
March 25, 2024 at 12:13 pmPrashanthAnsys Employee
As given in theory manual, we basically transform the velocities from stationary to moving frame to solve MRF governing equations.
- The topic ‘Solving MRF equation analytically’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Script error Code: 800a000d
- Cyclone (Stairmand) simulation using RSM
- Fluent fails with Intel MPI protocol on 2 nodes
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
543
523
225
209
