September 26, 2024 at 10:16 pm
ZenerDalf
SubscriberHi I am currently using HFSS and just changed a simple parameter in my simulation and my solver has been stuck on the following. The previous simulation I ran took abound 3 minutes to run due to the amount of passes I have set. I have also monitored by computer resources and the CPU is basically stagnant for anything HFSS related.
September 27, 2024 at 1:17 pm
Mrinmoy Bharadwaj
Ansys EmployeeThe provided details aren't enough to find the cause. Three first level suggestions can be (1) Check your connection with your license server if the licenses aren't local. (2) Try restarting your system and re-run the simulation (3) Try running the same simualtion in another machine. I hope these help.
