August 1, 2023 at 12:19 am
fraser.shields
SubscriberHello,
I have a model of a biphasic/poroelastic solid reinforced with elastic shells. I have replaced solid 186 elements with CPT216 elements to model the fluid pressure and flux when the construct is under compression. However, I am getting solver pivot errors when running the model. The model has shared topolgy between the solid and shells, and runs completely fine when it has solid 186 elements consititing of a linear elastic material. However, upon changing elements, the error arises.
Here is a link to the project:
https://drive.google.com/file/d/1P1JmyINikenVzwqfqQGCw94MCGd9vIDi/view?usp=sharingÂ
It contains the following ADPL command snippet in the analysis section:
!  Commands inserted into this file will be executed just prior to the ANSYS SOLVE command.!  These commands may supersede command settings set by Workbench.Â!  Active UNIT system in Workbench when this object was created: Metric (um, kg, uN, s, V, mA)!  NOTE: Any data that requires units (such as mass) is assumed to be in the consistent solver unit system.!        See Solving Units in the help system for more information.Â/PREP7Â! Define an element type with the desired real constant (CPT216)ET, 9991, CPT216KEYOPT, 9991, 12, 1! Select the solid elements you want to modify (SOLID186)ESEL, S, TYPE,, 13, 57! Modify the selected elements to use the specified element type (9991)EMODIF, ALL, TYPE, 9991ÂESEL, NONEÂ! Define proelastic material for solid elementsMP,EX,99999,0.001 ! YOUNG'S MODULUSMP,NUXY,99999,0.3 ! POISSON'S RATIOFPX=2e-15 ! PERMEABILITYONE=1.0TB,PM,99999,,2,PERMTBDATA,1,FPX,FPX,FPXTB,PM,99999,,2,BIOT ! BIOT COEFFICIENTTBDATA,1,ONEESEL, NONEÂ! Define linear elastic material for shell elementsÂMP,EX,88888,0.1 ! YOUNG'S MODULUSMP,NUXY,88888,0.3 ! POISSON'S RATIOÂÂ! Select the solid elements you want to modify and assign material 1ESEL, S, TYPE,, 9991MPCHG, 99999, ALLÂ! Select the shell elements you want to modify and assign material 2ESEL, S, TYPE,, 1, 12MPCHG, 88888, ALLÂ! Select all elementsALLSEL! Continue with the solution phase/SOLUÂÂAny help would be much appreciated.ÂThanks! -
August 3, 2023 at 6:14 am
Ashish Khemka
Forum ModeratorHi,
Ansys employees cannot download the attachments. The command snippet is used to change the material. Can you share snapshots of the setup - with that, it might be easier for forum members to comment more on your post.
Ashish Kumar
- The topic ‘Solver pivot issues of elastic shell snadwiched between poroelastic solid’ is closed to new replies.
5799
