Electronics
Electronics
Solver output verbosity Icepak AEDT
    • luis.maldonado
      Hi everyone,
      There is a way I can activate a verbosity log output file that allows me to see in real time what is happening with the Icepak AEDT solver.
      For instance, in Icepak Classic, you were able to see what was going on in the simulation through the command terminal opened by the solver, and also in real time, the solver is saving a .trn file that you can check.
      In Icepak AEDT, we have a similar file, but it is only created when the simulation finishes with a clean stop or successfully.
      What I am looking for is a way to be able to analyze why a simulation crashes in Icepak AEDT, since the one-line report doesn't work most of the time. I have seen a line message in the solver that says '==============', which I don't know what that means, and that's why it would be nice to check in a log file.
Viewing 0 reply threads
