September 16, 2020 at 12:33 pm
TomY610
SubscriberHello,
I am uses ANSYS 2020 R1 for school. I have downloaded the application on my desktop. When trying to solve my model, the loaded gets stuck at 10%. However, when I use Amazon Appstream, the same file solves perfectly fine. Has anyone else encountered a problem like this? Or have any idea what the issue could be? Thanks!
September 16, 2020 at 12:45 pmciema
SubscriberCan you attach error window?
September 16, 2020 at 8:13 pmSeptember 17, 2020 at 12:54 amciema
SubscriberCan you present model? Boundary conditions and mesh? It will be much easier to find the reason
September 17, 2020 at 8:20 pmGary_S
Ansys EmployeeThis can happen if the Distributed solver fails to start.
Try the non-Distrbuted solver.
In Mechanical, Home (Tab), -> Solve. Uncheck "Distributed" box.
Let us know if the solve progresses.
September 21, 2020 at 11:44 amTomY610
SubscriberIt worked! Thank you Gary!
Viewing 5 reply threads- The topic ‘Solver getting stuck at 10% in mechanical’ is closed to new replies.
Innovation SpaceTrending discussions- The legend values are not changing.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
4167
1487
1318
1171
