3D Design
3D Design
Solve undercut problem
    • Ludwig Stamm
      I have a model with existing undercut in direction Y
      Is it possible to use SpaceClaim to get rid of the undercut
      Does SpaceClaim have a feature to detect and remove undercut in a given direction?
      This is the model i am trying to edit:
      What i am trying to achieve would look something like this
      but obviously this is just a simplified model (with no curve in it):
    • Devendra Badgujar
      Hello lstamm
      Let me check and get back to you.
      Regards.
    • Devendra Badgujar
      Hello lstamm
      Please can share this model with us so as to understand the problem better?
    • Ludwig Stamm
      here is the model
      Thank you :)
            🛈      This post originally contained file attachments which have been removed in compliance with the updated     Ansys Learning Forum Terms & Conditions
      • Devendra Badgujar
        lstamm
        Thanks, will check and update you.
    • Devendra Badgujar
      Hi lstamm
      Currently there is no feature to automatically detect and remove undercut in a given direction.
      You generally need to edit it with some sort of geometry operation like pull, sweep, blend.
      SpaceClaim has a function where you can sweep a 3D object but the result is facets. I think if we swept it straight down, it would work....the result would be faceted, and you could try to skin it but that doesn't always work.
      It is not working in 2022 R2 release and we have filed a bug with the development team for this. Although it is working in 2021 R2 version. You might try this and see if that helps.
      In the image attach you can see there are no more undercuts but its faceted.
      Regards.
Viewing 4 reply threads
  • The topic ‘Solve undercut problem’ is closed to new replies.
