March 18, 2024 at 5:18 pm
li
SubscriberHi,
I have a Driven Terminal solution setup with a broadband solution frequency type between 0.5 - 4 GHz. However, when I right click on "Analysis"->"List", it appears to be solving at the single frequency of 5 GHz. Is this a bug? If not, what is the significance of the displayed value of 5 GHz, and how may I change this? Thanks.
March 26, 2024 at 5:49 pm
Praneeth
Ansys EmployeeHi Richard,
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
Please let us know the version of Ansys EDT in which you are seeing this issue to help us serve you better. I have verified on my side and it showing as broadband sweep only.
Best regards,
Praneeth.
- The topic ‘Solution Setup Discrepancy?’ is closed to new replies.
