April 21, 2022 at 6:03 am
SilverRD
SubscriberApril 21, 2022 at 7:21 amNikhil N
SubscriberHello,
1: With the 'Flux Type' user can select the method to calculate Mass Flux while solving. The methods you see here will change if you select Density based solver.
2: For compressible fluids, it is recommended to select 'Rhie-Chow: distance based' method.
For more details on the Flux method, please refer to there two links:
1: For pressure based solver: 32.3.2. Mass Flux Types (ansys.com)
2: For density based solver: 32.4.2. Convective Flux Types (ansys.com)
If you are facing issue while accessing the above links, please refer to this forum discussion: Using Help with links ÔÇö Ansys Learning Forum
Nikhil
April 22, 2022 at 6:08 amSilverRD
SubscriberThank you I really appreciate your help...
April 22, 2022 at 6:14 amNikhil N
SubscriberYou are welcome!
Nikhil
September 27, 2022 at 1:43 am
lancer
SubscriberIs this available in ANSYS 2021 R1 because I couldn't find it?
Viewing 3 reply threads- The topic ‘Solution Method – Flux Type’ is closed to new replies.
5874
1306
