November 12, 2024 at 11:29 am
Leonardo
SubscriberOlá comunidade CFD.
Na tentativa de rodar uma simulação de ventilação geral diluidora em um galpão (edificação de grande porte) o Transcript do Solve Physics evoluiu apenas até a parte de "Solution Initialization", não saindo mais daà (imagem anexo).
Alguem saberia dizer o que pode ser?
Hello CFD community.ÂIn an attempt to run a simulation of general dilution ventilation in a warehouse (large building), the Solve Physics Transcript only progressed to the "Solution Initialization" part, and did not go beyond that (attached image).ÂDoes anyone know what this could be? -
November 12, 2024 at 12:07 pm
Forum ModeratorOdd, the hybrid scheme shouldn't take too long to run and then pass to solve. Can you open the transcript and see what's going on?Â
Just an aside, should the gas density vary with temperature as buoyancy may be significant in low flow HVAC domains.Â
1890
1414
1304
