December 3, 2023 at 7:23 pm
Md_Salem
SubscriberHello everyone
I am doing a modal analysis and when I tried to check the solution information the workbench gave me blank sheet named "post output".
How can I retrive the solution information ?
December 4, 2023 at 7:56 am
Akshay Maniyar
Ansys EmployeeHi,
Are you able to see other outputs under solution information like participation factor or solver output? Please check the knowledge article, I have attached the link for your reference.
Thanks,Â
Akshay Maniyar
December 4, 2023 at 8:38 am
December 4, 2023 at 9:56 am
Akshay Maniyar
Ansys EmployeeHi,
Are you able to see other outputs like solver output or participation factor? Can you share the settings you are using for the command snippet?
Thanks,
Akshay Maniyar
- The topic ‘solution information is not available’ is closed to new replies.
1587
1386
1242
