Systems
Systems
Topics related to Twin Builder, medini analyze, VRXPERIENCE and more.
Solution Field export as Bin file format for Twin Builder static ROM builder
    • Amirhossein Fardi
      Hello.
      In Ansys Twin Builder help in static ROM builder section, it's describe the snapshots and points file format. By default, I couldn't find the built-in export menu, which is compatible with static ROM builder. So I created some python code to get mesh coordinations and their solution field value's from ansys mechanical. I put them in subfolders as noted in help document. But unfortunately, it doesn't work.
      I create those files in text format and then rename it to Bin :) .
      Do you have any idea how to create these Bin files in right format?
      Thank you
    • Amirhossein Fardi
      any help ? Idea ?
    • Jose Luis Gonzalez Hernandez
      If you are using Mechanical, there is a preprocessing app available in the Ansys Customer Portal. Go to Downloads > Add On Packages > Static ROM Preprocessing for Mechanical. You will find documentation on how to use the app. The app will generate all the binary files and file structure needed for ROM creation.
      Best,
      Jose Luis
      • Amirhossein Fardi
        thank you for you help.
        Unfortunatly i have no access to customer portal which is mean no access to that package for now.
        Isn't there any guidance that i could write the programme by myself ?
  • The topic ‘Solution Field export as Bin file format for Twin Builder static ROM builder’ is closed to new replies.
