March 15, 2021 at 10:50 am
AAchi
SubscriberMarch 15, 2021 at 3:58 pm1shan
Ansys Employee,nCould you perform a modal analysis to check if the model has sufficient constraint(see if you have any near zero natural frequencies)? Also, try using a smaller moment (1Nmm) value and see if the same error persists. nRegards,nIshan.nViewing 1 reply thread- The topic ‘Solution error in static structural’ is closed to new replies.
6019
