Solution converged
    • Ananth Narayan
      Hello everybody,
                               May I know the meaning for the statement " Solution has converged". What this implies about the solution.
      Regards
    • seeta gunti
      Solution has converged tells you that your simulation has reached to unique solution and it is ready for post-processing. This statement generally comes once the case residuals reaches to the limits  ( set by you). By default, Fluent sets to 1e-03.
      Many cases, if the residuals are reached to 1e-03, solution would converge but for better converging the case, it is suggested to check the mass balance, energy balance also. Apart from this, you can set the monitors and check the converge for the monitors as well.
      Seeta
    • Ananth Narayan
      First what is residual?. Are there any tutorial to set monitors to check converge.
    • Keyur Kanade
      Residuals are local imbalance of variable over control volume. This arises from the CFD methods applied.
      Request you to go through basics of CFD to understand the numerical methods. Also please check help manual on convergence.
    • Ananth Narayan
      Can you suggest books or tutorial for all basic terms related to ANSYS CFD
    • Keyur Kanade
      Please check following section on forum.
      https://studentcommunity.ansys.com/cat/support-resources-tutorials/
Viewing 5 reply threads
  • The topic ‘Solution converged’ is closed to new replies.
