November 5, 2021 at 8:52 am
Luca Di Rosa
SubscriberI am getting error opening Solidworks 2021 files in Spaceclaim 2021 R2
! No B-Rep data in input file
File is valid and can be opened with no issues on Rhino v7.
Any clue?
Thanks
file attached
November 5, 2021 at 9:01 am
Luca Di Rosa
Subscribertest file here? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
November 8, 2021 at 5:19 am
Charudatta Bandgar
SubscriberHello Luca
Let me try this on my end and see if it can be recreated, I will file a bug it is seen.
Regards.
November 8, 2021 at 5:45 am
Charudatta Bandgar
SubscriberHello Luca Yes, even I am noticing the issue. Ideally it should be supporting SW2021. Is this the case with all SW2021 files or just the one attached? I will confirm with the team if there is any known issue. The file attached in this query does open without any error though, so I am not sure if it is file specific or not. I have highlighted these observations to the developers and have filed a bug ticket (546277), to understand better. Regards-
November 8, 2021 at 9:17 am
Luca Di Rosa
SubscriberHello Charudatta BandgarÂ
looks like this issue is specific to some files only (in my case only 5parts opened successfully out of 35).
I would think this to be a SC bug as the complete assembly is opened fine on Rhino 7.
Thanks!
November 8, 2021 at 9:42 am
Charudatta Bandgar
SubscriberLuca That could be possible yes. I will get back to you as I hear back from the developers.
Regards.
December 29, 2021 at 6:09 am
Charudatta Bandgar
SubscriberHey Luca
This has been fixed in 2022 R2 (22.2).
Regards.
December 29, 2021 at 7:27 am
Luca Di Rosa
SubscriberThank you, when will it be released? If I am not wrong we are still at 2021R2
- The topic ‘Solidworks 2021 – Still no support or bug?’ is closed to new replies.
