January 6, 2024 at 4:37 pm
Shivansh Karanwal
SubscriberI am getting some problem with the solidification/melting model coupled with VOF (with evaporation and condensation). In the problem when Liquid nitrogen spray strikes the gel surface (there is no wall in between), the region beyond the agarose gel (the region where only nitrogen gas is present) is also getting solidified. Please suggest some solution for this.Â
January 8, 2024 at 11:41 am
Forum ModeratorPlease can you post some images? Also, check the phase material in the region you're seeing the solid. Depending on convergence you may have a tiny volume fraction of the gel in the gas region that's causing some confusion when post processing.Â
- The topic ‘Solidification of a gel (fluid) by the spray of liquid nitrogen.’ is closed to new replies.
1515
1386
1209
