November 15, 2021 at 8:19 am
Roberto
SubscriberHelloÂ
I can't wrap the solid drilled, the software loads and eventually releases an error why?
After you get the file please delete it from the forum
Regards
November 15, 2021 at 8:28 am
Devendra Badgujar
Forum ModeratorHi Roberto
Let me look into this and will get back to you.
November 17, 2021 at 1:34 pm
Roberto
SubscriberHi Devendra Badgujar
Do you have any news? The file is a bit urgent
Regards
November 17, 2021 at 1:53 pm
Devendra Badgujar
I checked the model file and was able to reproduce the issue.Â
I will raise a bug for the issue with the developers and will update you once I get any more information on this.
Regards.
November 17, 2021 at 2:20 pm
Devendra Badgujar
I have submitted BUG ( 551691 ). I will update you as I hear from the development team about this bug.
April 11, 2022 at 6:55 am
Devendra Badgujar
I have an update on this bug from the development team:
The wrap extends beyond the boundary of the target and is doubly-curved. Doubly-curved objects can only be used as a target if the curvature is mild. With stronger curvature distortion is produced causing the source to "break". If this case is detected, the wrap will fail.
April 12, 2022 at 6:56 am
Roberto
SubscriberDevendra Badgujar Hello
Thanks for explaining the problem to me
Regards
- The topic ‘Solid wrap’ is closed to new replies.
3407
1057
1051
896
887
