August 23, 2021 at 11:39 pm
LucasMatheus
SubscriberGood night,
I need to simulate a sandwich beam, balsa wood core with carbon fiber in the top and bottom. This beam has variable cross section area, image below. After configuring the laminated material, I create the static structural analysis system, but when I add the configuration made in ACP, I only have the option to choose the shell or the solid. How could I run a simulation with the solid and shell together?
August 24, 2021 at 1:45 pmGovindan Nagappan
Ansys Employee@LucasMatheus
You will need two ACP Pre systems - One for solid and one for shell
Just duplicate the ACP Pre system you have and connect it to the same Static structural. From one system, you can import the solid and from the other system you can import the shell
Static structural should have the assembly.
Here is a sample schematic:
Viewing 1 reply thread- The topic ‘Solid + Shell ACP Analysis’ is closed to new replies.
5649
1885
1404
1303
